Can't get pads out
zxr_oli
My Bike: Daytona 675
Can't get pads out
Post by zxr_oli »
Trying to change my pads etc.
Got the front ones out but the pins holding the rears in are stuck tight. Tried leaving WD40 to soak in + a lot of brake cleaner but they're stuck fast.
Anyone got any tips?
Re: Can't get pads out
drill out the captive side and drive them out with a punch, then fill the holes you made with epoxy/metal putty/similar. it happens a lot.
be interested to find out other peoples ways of shifting these, i need to change my pads for the mot and the pins are stuck well fast so thinking of stripping the calipers, if everyone posts their experiences i'll do a write up with tips.
ive tried gripping them with vice grips and attempting to twist them out after a liberal soaking in penetrating fluid.. its just snapped the pins :( ..
i was thinking of drilling them out and then replacing them with gsxr ones that screw in which would mean drilling out the holes and tapping them.
sounds like a plan Baz, the original design, is pants.
Captain Awesome
My Bike: ZXR 400 L9 '52
Post by Captain Awesome »
I found that if you grab the pin with a small set of pliers or wire cutters and then tap the gripped end with a hammer forces the pin out :excited
see here for removing the pins viewtopic.php?f=55&t=6497
