carb balancing
ZXRSHAUN
- My Bike: ZX4R L3
carb balancing
Is it better to have a high or low vacuum pressure when balancing carbs and what characteristics will this give if either high or low if any? also at what RPM should the carbs be balanced at i assume just on idle any help would be much appreciated.
ZX4R L3
stug
- My Bike: Yamaha R1
Re: carb balancing
I have Morgan gauges and they reckon raise your tickover to 1500rpm or above as this smooths out the engine while balancing and this helps to give you a better reading on the gauges.
Re: carb balancing
I raise the idle to between 2 and 3 k when balancing
ZXRSHAUN
- My Bike: ZX4R L3
Re: carb balancing
ok thanks alot, does it matter about the reading just aslong as they read the same
ZX4R L3
stug
Re: carb balancing
You are looking to get all the dials, rods or what ever your gauges have to equal the same.
i.e. the all sit in a line with none higher than the rest.
It is almost impossible to have them all exactly the same, but just get them as close as you can by turning the adjusters very small amounts at a time
lewisdale
- CBT slow
- My Bike: zxr400 H2
Re: carb balancing
when you say turning the adjusters, is this something thats on the carbs?
Re: carb balancing
yes mate 3 screws at the back of the carbs. 1 to balance 1&2 , 1 to balance 3&4 and the middle one balances both pairs together
nc73
- My Bike: zxr400 L
Re: carb balancing
sorry to
the thread...was wondering how much time it takes to balance the carbs? borrowing vac gauges this weekend..
