Brakes
Chris1984
Brakes
Post by Chris1984 »
I want to remove front brake caliper completely,if i undo the brake pipe is it a case of just putting back on when finished or does it hae to be bleeded etc.
Re: Brakes
you will need to bleed it mate, easy enough job.
Chris1984
Re: Brakes
Post by Chris1984 »
masterofinsanity wrote:you will need to bleed it mate, easy enough job.
Nice one have them off now going to give them a very good clean think one of the pistons is sticking,so is it best to buy new one?
Re: Brakes
nah whip it ou and give it a good polish up, just dont grip it with pliers or the vice as it will gouge it.
Chris1984
Re: Brakes
Post by Chris1984 »
masterofinsanity wrote:nah whip it ou and give it a good polish up, just dont grip it with pliers or the vice as it will gouge it.
how do i get the piston out after i have taken it all apart should i have done this before i took the fluid out.i also sprayed the whole caliper with brake cleaner and scrubbed with a toothbrush but the dirt did not shift is there anything else i can use apart from brake cleaner?
